im having problems still...
Old Jan 16, 2009 | 03:56 PM
jojoenglish85's Avatar
Default im having problems still...
So i bought the correct brand new MAF to replace my bad one, i hooked it up and the car seems to run fine, but the check engine light is back on and the maf code keeps popping up, what the hell do i do now?
Old Jan 16, 2009 | 04:01 PM
Murderface's Avatar
Good question...do you have any intake mods?
ITG dro
Well that mod will definitely only make your car's performance SEEM more intense LOL
Old Jan 16, 2009 | 04:32 PM
ya just a cone filter from autozone
Old Jan 16, 2009 | 06:18 PM
jakej's Avatar
what do you concider the "maf code"?
Old Jan 16, 2009 | 08:17 PM
achTTung's Avatar
Should have 6" of straight tube between your filter and your MAF, or the turbulent air could cause a false reading.
Old Jan 17, 2009 | 01:49 PM
p0102 is the code im still getting. so i can't do anything as far as inspection goes untill its fixed lol.
Old Jan 19, 2009 | 06:38 PM
anyone know what i should do, or why its still throwing this code?
Its realy annoying
Old Jan 20, 2009 | 03:16 AM
Murderface's Avatar
Try throwing your stock airbox back in see if it helps.
Although I've been running an open intake clamped right on the MAF housing without issue for a while now.
Old Jan 20, 2009 | 10:01 AM
cincyTT's Avatar
I'm make believe
You are running a much larger turbo than what the ecu/maf expects. Pretty sure thats the reason you are having maf errors since its probably seeing way to high g/s
Old Jan 20, 2009 | 07:01 PM
Hurray!!! I passed inspection, i just needed to clear the code and drive the car for about 15miles on the hwy after the reset, and it was all good.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
