Just blew another samco hose!
Old Jan 16, 2008 | 06:08 PM
Mac_17's Avatar
Default Just blew another samco hose!
Any ideas on how to keep those things attached to the intercooler because everytime I get it back from the shop it blows off. Any ideas?
Old Jan 16, 2008 | 06:11 PM
porc933's Avatar
Default RE: Just blew another samco hose!
Duct tape. J/K
Old Jan 16, 2008 | 06:52 PM
beachchair's Avatar
If the hose is blowing off and not splitting, chances are there is some grease, oil or dirt on the hose that is keeping it from securing. They are designed pretty well with clips, and hose clamps so it sounds like you are not getting a good connection to start with.
Old Jan 16, 2008 | 06:57 PM
Mac_17's Avatar
Hmm.. interesting, I wonder if I have some crap in the intercooler that is leaking over. Any ideas on how to clean the intercooler, I might just take it out today.
Jason
Old Jan 16, 2008 | 07:26 PM
moeron7's Avatar
Use Carb cleaner
Old Jan 16, 2008 | 07:50 PM
TT_GUY's Avatar
are you using T-Bolt clamps?
Old Jan 17, 2008 | 10:31 AM
Mac_17's Avatar
Yes I have t bolt clamps on there, I am thinking I might slide another clamp on there because this is the second hose that hase blown.
Old Jan 17, 2008 | 11:07 AM
cincyTT's Avatar
I'm make believe
Most likely you have oil in the ic(s). Mainly the drivers side. You should drain them and clean the TB while your at it. To keep the hoses on, spray the ends of the pipes with hairspray, it will tach it almost like glue and you shouldnt have a problem.
Old Jan 17, 2008 | 12:37 PM
Mac_17's Avatar
Thanks cincy, I will try that, the only problem is getting my damn car home to work on.
Jason
Old Jan 17, 2008 | 12:39 PM
WishIWasRWD's Avatar
Hairspray, like cincy said.
If it's bad enough that that doesn't work, have them weld a bead on the edge of the pipe and clamp before that. Make sure it's smooth so it doesn't damage the hose.
fourringking
May 20, 2012 07:38 PM
jely1
May 27, 2009 01:17 PM
SharpHID
Feb 20, 2008 02:03 AM
vos103
Oct 20, 2006 01:04 PM
socals4driver
Oct 17, 2006 03:48 AM
