Just installed Turbosmart BOV but have a weird sound
Old Jul 6, 2007 | 12:12 AM
LovemyAudi's Avatar
Default Just installed Turbosmart BOV but have a weird sound
Hey this is an audi noob who just installed a turbosmart BOV for my audi TT 1.8T and i kno that its supposed to make a pshh sound ... well according to the people who ive spoken to, but i get a weird turkey noise like a wobbling noise... i installed it like the picture attached but i was wondering what i did wrong or is it because i need to adjust other things in my car?
[IMG]local://upfiles/37765/37F25193E226405AA8C7D155C6792923.jpg[/IMG]
Old Jul 6, 2007 | 09:57 AM
TTempted's Avatar
Default RE: Just installed Turbosmart BOV but have a weird sound
From the FAQ:
Q.What BOV will work with my car?
A. Ask this question and you may get flamed. Dont know what that is ask and find out. No, seriously the TT was not designed to work with a BOV. It uses a divertion valve instead, companies like Forge and Stratmosphere make very reliable DVs for the TT. You may want to make sure that your DV that you get, you can "tune" so in the future when you run higher boost it will be able to hold it and you can get the max performance out of you turbo. *You will need a new DV after chipping your TT* The stock one will most likely go out due to its OEM design. There are a couple of BOV that willwork with the TT. These are"dual"BOVs meaning thattheyvent both into the intake and intooutside air.One oftheseisHKS Super SequentialBOV. I am not sure of others.
But really, it's a dual bov, right? The photo doesn't look the same as some of the others I found online.
Old Jul 6, 2007 | 12:44 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: TTempted
From the FAQ:
seriously.....
and you helped how? Oh yeah, i run a FULL 100% BOV
Old Jul 6, 2007 | 12:47 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: LovemyAudi
You have it installed correctly. The noise you are hearing is "flutter" you need to loosen the tension on the valve a tad until it goes away at higher boost. You may get some at low psi (~5psi), just as long as its clean at peak boost (whatever you are set for).
Old Jul 6, 2007 | 12:50 PM
TTempted's Avatar
So do you get an email every time I post or do you just actively wait for me to respond to threads? I posted that thread and asked if it was dual. Is that okay, sir?
Old Jul 6, 2007 | 01:02 PM
cincyTT's Avatar
I'm make believe
how do i follow you? I just read threads.
its the same as all the rest of the hybrids/duals.
Old Jul 6, 2007 | 01:28 PM
TTempted's Avatar
I was attempting to familiarize myself with a turbosmart bov. The original poster said he was an audi noob and referred to it as a BOV. How the hell am I supposed to know that it was a hybrid or dual? Oh, that's right, by asking. But wait... that's what I did and you came down on me in the douchiest way possible.
Old Jul 6, 2007 | 01:33 PM
cincyTT's Avatar
I'm make believe
do you not see in plumbed right back into the intake? Come on now, you act like you know it all and then ask these questions.
Old Jul 6, 2007 | 01:34 PM
LovemyAudi's Avatar
It should be dual because the box that i received it in and the manual that i got with it said it was a dual port but it may be wrong box, im not really sure because the person that i bought it from said it was used for a few weeks, and i actually went on google to search for a dual port bov but it did look different from mine
and when you say to loosen the tension on the valve do i just unscrew the hose clamps a tad? im sorry if this sounds stupid
and thanks for fast help guys
Old Jul 6, 2007 | 01:40 PM
cincyTT's Avatar
I'm make believe
yes, you have a dual port (manufactures call it differnt things)
Turn the silver top to loosen the valve. Should be counter clockwise acouple clicks at a time till it goes away.
