koni shocks owners?
the koni struts comes in compressed i believe, how do you decompress them? do you just pull them apart and then install them? i could pull them and compress them again, is that normal?[/align]
RE: koni shocks owners?
I worked on a lift so decompressingmy Koni sportswasn't an issue.
I can tell you that Koni sports are hydraulic,instead of being gas infalted. So it's notthe typical once you cut theribbon you're screwed sorta deal. |
i just installed it, i didnt do anything else. im not sure what else should be done
The shocks are really easy. Two bolts and one comes out. With the Koni yellows, they are hydraulic like Becca said so you can just push and pull them in as needed.
are you guys serious https://www.audiforums.com/micons/m13.gifi just stretched the shocks for the rear to reach the two ends of the bolts, it acts like the oem shocks but it doesnt expand back like the oem. tell me what am i missing? right out of the box, i installed it like it is bolt on.
ORIGINAL: hotgrass are you guys serious https://www.audiforums.com/micons/m13.gifi just stretched the shocks for the rear to reach the two ends of the bolts, it acts like the oem shocks but it doesnt expand back like the oem. tell me what am i missing? right out of the box, i installed it like it is bolt on. |
Rear shock adjustment procedure. http://www.konina.com/comp.cfm
page not found
http://www.koni-na.com/comp.cfmshe forgot the hyphen :-)
Woops! Sorry about that! Thanks for having my back mysteryman! :)
