Lambda Regulation and Cat Readiness
Old Apr 25, 2008 | 10:56 AM
JettaRedII's Avatar
Default Lambda Regulation and Cat Readiness
A common problem with after market downpipes and cats is that you eventually get an error code associated with the O2 sensor efficiency or the readiness code never gets set. The Wayne's Angle Block and spark plug anti-foulers are a fix that sometimes works.
Has anyone figured out how to force the readiness or avoided DTCs using Unisettings or Lemmiwinks? Specifically, can adjusting the value of Channel 06 (Lambda Regulation) up or down force readiness or avoid DTCs?
Old Apr 25, 2008 | 11:11 AM
MeanAudiA6's Avatar
Default RE: Lambda Regulation and Cat Readiness
i asked this very question on many forums about 6 months ago and got no answer that was of any help lol all suggested waynes angle block...
Old Apr 25, 2008 | 11:13 AM
cincyTT's Avatar
I'm make believe
You either have to space out the sensor or have the chip tuner write in a code that eliminates the cel from coming on.
Old Apr 25, 2008 | 12:22 PM
JettaRedII's Avatar
ORIGINAL: cincyTT
You either have to ...have the chip tuner write in a code that eliminates the cel from coming on.
I think that's what Revo does (or did).
Old Apr 25, 2008 | 12:29 PM
JettaRedII's Avatar
Any idea which O2 sensor is affected by the Channel 06 settings? Which sensor is call the narrow-band sensor?
Old Apr 25, 2008 | 12:36 PM
.clipse's Avatar
SoCal Crew Member
i got my wayne's angled blockfor $36 shipped
didn't know that machined little block cost so much
Old Apr 25, 2008 | 12:39 PM
JettaRedII's Avatar
I have wayne's angle block already, but still got a P1176 code yesterday.
Old Apr 25, 2008 | 12:45 PM
.clipse's Avatar
SoCal Crew Member
^ really, the block threw a code? how long have you had it? testpipe?
also, i know about 1/4 of the maganflow hi-flow cats throw CELs
Old Apr 25, 2008 | 12:50 PM
JettaRedII's Avatar
Probably about 10 days. Not a testpipe, but 42dd 3" dp with hi-flo cat.
Old Apr 25, 2008 | 07:24 PM
cincyTT's Avatar
I'm make believe
Both front and back are nbo2's on nonVVT cars and just the rears are narrowband on VVT cars. There is a lemmiwinks guide on vortex in the 1.8t section that break down what every channel does
