Lambda Regulation and Cat Readiness
A common problem with after market downpipes and cats is that you eventually get an error code associated with the O2 sensor efficiency or the readiness code never gets set. The Wayne's Angle Block and spark plug anti-foulers are a fix that sometimes works.
Has anyone figured out how to force the readiness or avoided DTCs using Unisettings or Lemmiwinks? Specifically, can adjusting the value of Channel 06 (Lambda Regulation) up or down force readiness or avoid DTCs?
Both front and back are nbo2's on nonVVT cars and just the rears are narrowband on VVT cars. There is a lemmiwinks guide on vortex in the 1.8t section that break down what every channel does
