Lost the sensor retainer clip
Old May 29, 2008 | 09:27 PM
kwaskow's Avatar
Default Lost the sensor retainer clip
Changing the temp sensor is certainly easy enough, but I lost the retainer clip somewhere in the engine compartment.....since I don't have an Audi dealer nearby, can I get the clip from the VW dealer, and if so, does someone have the part number?
Thanks!
Old May 29, 2008 | 09:39 PM
cincyTT's Avatar
I'm make believe
Default RE: Lost the sensor retainer clip
vagcat has it listed as 095323969
Didnt go and look so i hope thats right. It did same temp sensor.
Old May 29, 2008 | 09:54 PM
kwaskow's Avatar
Cincy - thank you. Just to clarify....the VW is the same sensor?
Old May 29, 2008 | 09:55 PM
cincyTT's Avatar
I'm make believe
they all should use the same sensor.
Old May 30, 2008 | 01:52 PM
kwaskow's Avatar
Looks like a winner....one question though: with the new sensor installed, the temp gauge read one quarter deflection, where it used to read one hlaf deflection at operating temp...then several miles later it climbed to one half. Does the new sensor require a short burn in period?
Old May 30, 2008 | 03:48 PM
cincyTT's Avatar
I'm make believe
You are talking about coolant temp, thesensor you just installed is for measuring the temp of the air in the intake manfold. If you think you are heating up slower, check the vac line to the combi valve. Its is the silver circle just behind and below the breather on the valve cover.
Old May 30, 2008 | 05:33 PM
kwaskow's Avatar
whoa - now I am major confused......this sensior went into a coolant line, in fact some coolant spilled on the floor
Old May 30, 2008 | 05:43 PM
cincyTT's Avatar
I'm make believe
My bad, i thought you were talking about the iat sensor, not the coolent sensor. The part # i gave you was for the new intake temp sensor.
Old May 30, 2008 | 06:01 PM
kwaskow's Avatar
So back to my querry:
Old Jun 2, 2008 | 10:39 PM
kwaskow's Avatar
OK - need more help, please. Another engine code, this time 2181, and again coolant related. need help please, before I take her to the dealer.I have the green top sensor in, and strangely the temp gauge is still acting wierd since the swap. Almost acts like the t-stat is stuck open now. I know all these issues are intrelated.
burgermeiser
Feb 28, 2014 04:10 PM
sleek55044
May 17, 2012 02:27 PM
primo382
Jun 14, 2010 04:26 PM
OKIE
Nov 7, 2009 02:19 AM
GraffixWB
May 9, 2006 11:32 PM
