MAF 5 pins plug has 4 pins
Well I've been troubleshooting a boost issue and I just noticed this when I was putting everything back together. I came across a couple posts on other boards and it seems to be that the female connector does indeed have only 4 contacts while the MAF has 5 male pins.
Got another question. Not sure if you know the answer but is limp mode accomplished by affecting the N75 valve? I mean is that how the car enables limp mode? I've already found and repaired a couple leaks and I'm going to test once again but I'm just trying to understand everything involved. Thanks.
Correct, everytime I play around with the N75, I go into limp mode.
I have installed a MBC and I had to plug the ports of the N75, keeping it electrically plugged in, so I can cheat the ECU. I run about 20psi of boost and hold around 17-18psi
I run Maff-Less so I will check the connections and see whats up.
OK. I'm about to go do another leak test to make sure I haven't missed anything. How do you run w/o MAF w/o messing up your fuel air ratio?
Guess maybe I'll order a MBC. Not too much $$ Any chance you could post pics of how your N75 is plugged? Thanks.
