MBC questions/problems
Old Jun 18, 2007 | 01:45 PM
timbo108's Avatar
Default MBC questions/problems
I had installed a Voodoo MBC on my GIAC chipped '01 225Q. There is a Hyperboost DV in place. I kept the N75 connector plug in place, plugged the N75 nipplesand swapped the two hoses from the N75 to the MBC as per the directions. I used the coarse and fine adjustments to run at 22 peak.
Problem is, it randomly throws a fit, the traction control/EPC lights come on and the car defaults to some kind of limp mode (engine only idles, no rpm raise). Really sucks when your on the road. When I stop, turn off the ignition, let is sit for a minute or so and then re-start, all seems ok util the next time. Anyone experience this or similar ? If limited to 22 boost I shouldn't be tripping and over boost situation right ?
Old Jun 18, 2007 | 02:05 PM
techbod's Avatar
Default RE: MBC questions/problems
mods not my 4t but I would guess a software problem
Old Jun 19, 2007 | 03:32 PM
cincyTT's Avatar
I'm make believe
giac seems to have a problem over certain psi with some cars, see what others are running with gaic chips. you may want to use less course and more fine adjustment on you mbc. the course (ball and spring) isnt helping your cause to much and the fine will limit spiking.
noxtempusumbra
Mar 27, 2009 08:11 PM
IronMan111
Dec 30, 2008 06:13 PM
jeffwe
Jan 13, 2008 09:12 PM
Mykull
Dec 16, 2006 06:51 PM
Scorpion
Mar 23, 2005 09:37 PM
