AudiForums.com
-   Audi TT (https://www.audiforums.com/forum/audi-tt-7/)
-   -   N75 question (https://www.audiforums.com/forum/audi-tt-7/n75-question-66759/)
JaceTun Jun 18, 2007 03:00 AM
N75 question
I was planning to purchase a 4.0 Bar and a N75 from ECS
here is the link of the n75
http://www.ecstuning.com/stage/edpd/...mp;engine=1.8T
I heard that n75 works better when the car is chipped, should I wait untill the car is chipped before putting it on?
Also, how does n75 do good to my TT by itself?? Or should I get something else to complement it?
225tt Jun 18, 2007 09:38 AM
RE: N75 question
If you do some looking around you will find out that the N75 valve is really not needed a boost controller will do the same thing or better.
ouTTie914 Jun 18, 2007 10:05 AM
RE: N75 question
Why do you need a 4 bar FPR? What mods do you currently have?
JaceTun Jun 18, 2007 11:35 AM
RE: N75 question
I ordered a mofo from modshack, I had my borla exhaust, hyperbooster DV. I am waiting to get my car chipped as long as the owner of the shop cured his back pain. I have read that the BM does better, I will put that in conisderation since yall' highly recommend that. I have no idea how to install it, i hope it doesn't take a lot of work.
For the mofo, it says it won't compatible for a stock airbox, is that ture? Or it just a way to get you to buy his product?
cincyTT Jun 18, 2007 12:48 PM
RE: N75 question
the id is larger than the stock maf but the od remains the same, so it fits. The boostmachine is just an expensive bleed valve mbc, you can get a good mbc for $20-100 and have the same results. Also a mbc is far easier to install and set.
JaceTun Jun 18, 2007 05:32 PM
RE: N75 question
I am very ignorance on machanic. From reading on CincyTT's thread about getting to 20psi without chip. I learned that 4.0 bar FPR- to regulate the fuel pressure, diode-keep the car getting into limp mode and the MBC-to adjust the boost level.(Correct me if i am wrong)
This is what I am going to do. I am getting a 4.0bar,MBC and a n75 from ECS tunning.
Since I am getting my car chipped, do I need to get diode mod done too?
If I install all these partsafter chipped without the diode, am I going to get the same result as you described?
cincyTT Jun 19, 2007 03:27 PM
RE: N75 question
if you get a chip you dont need a diode. also if you get a mbc, you dont need to change your stock n75 either. and lastly you dont need a 4 bar for fueling with a chip unless you have one written for it (revo stage 2) orif you geta mofo.
