need verification
Old Aug 5, 2012 | 10:34 AM
wardhill's Avatar
Default need verification
Hi,
i'm trying to re-install a stock down pipe for an 180hp quattro TT. The old one was broken at the flex pipe so I was able to take half out from underneath the car and the remaing part bolted to the turbo from the top of the car. I've read that it should be possible to re-install a compete stock unit from underneath without dropping the subframe but I'm not having any success getting the front flange of the downpipe to clear the cross frame and shaft. It it really possible?
Thanks
Jeff
Old Aug 8, 2012 | 04:34 PM
Clrwatrtom's Avatar
To the best of my understanding, the Quattro is a 225 hp motor. Are you sure you have the right part?
Old Aug 22, 2012 | 04:07 AM
Joe Edgerton's Avatar
not all quattros are 225. there are 180 models.
In your case you have to drop the subframe, the awd drive shaft restricts access to pull the pipe out. aftermarket ones though are known to resolve this.
If you do lower your sub frame get a alignment afterwards
Old Aug 22, 2012 | 09:27 AM
Clrwatrtom's Avatar
Thanks Joe. Do you happen to know where I can find more info on the tt build platforms?
Old Aug 22, 2012 | 02:17 PM
VWvortex - audi/VW technical - 1.8t engines - FAQs
VWvortex - audi - TTmk1 - FAQs too will have more specfic info to TT
Old Aug 23, 2012 | 09:28 AM
Clrwatrtom's Avatar
thanks Joe
Sergeant Larson
Oct 11, 2014 06:53 PM
phatjames167
Mar 15, 2013 08:19 PM
derrat
May 17, 2008 11:04 AM
