Normal Engine Temperature
Old Sep 27, 2006 | 02:55 AM
jthemis's Avatar
Default Normal Engine Temperature
Got a quick one.... My friend has an 01 TT, not sure of anymore details but she had some cooling work done on the vehicle. The temp guage shows that it may be running hot. It is showing one line above the 1/2 way point. From my minimum research, i understand the guage malfunctions are common, and the engine runs hot because of the close quarters in the engine compartment. I am just trying to get a feel to determine what the normal operating temp should be.
Thanks,
Jim
Old Sep 27, 2006 | 03:02 AM
MeanAudiA6's Avatar
Default RE: Normal Engine Temperature
replace coolant temp sensor easy 5 dollar fix ecstuning.com or ttstuff.com
Old Oct 17, 2006 | 03:36 PM
bmwtoaudi's Avatar
Mine shoes it running one knotch below the center mark, (I just bought it yesterday, I was also wondering what is normal) I was curising in 5th gear for 250miles.
Sound about right?
Old Oct 17, 2006 | 04:22 PM
ouTTie914's Avatar
My temp. gauge always sits in the middle, even when I get on it (after it warms up of course).
Old Oct 17, 2006 | 04:31 PM
stephenson27's Avatar
I drive mine everyday to and from work and it is always right in the middle. This past weekend I took it to a local road track and after running eight thirty minute runs with around thirty minutes break in between runs it was still in the middle but was edging up just a little.
Old Oct 17, 2006 | 04:43 PM
bmwtoaudi's Avatar
Do you think it running " cooler " is an issue...or maybe a bad temp gauge?
~Chris
Old Oct 18, 2006 | 04:04 AM
BlackRaptor's Avatar
Anyone used Water wetter to bring down there engine temps?
Old Oct 18, 2006 | 11:49 AM
XCLR8TT's Avatar
ORIGINAL: BlackRaptor
Don't do it. Water Wetter will create sludge when mixed with G12. Do a search on the Audiworld forum and you will see there are many accounts that attest to this.
Old Oct 18, 2006 | 05:03 PM
racer_x's Avatar
You're not going to be running too cool, don't worry.
If your therm. guage reads cool, replace it.
If it reads hot, replace it as well. Check coolant system, fan, etc.
Old Oct 25, 2006 | 08:08 PM
RussTT's Avatar
I purchased a 160 degree thermostat and that works well for keeping the motor cooler but the guage still reads middle once its warmed up.
