Oil Sensor Light
The Oil Sensor Light just came on in my '01 TT 225 Roadster. I changed the oil (after the light came on) with 5W30 Mobil1 Synthetic & the light is still coming on. I cannot find any information about this light in the owners manual nor does it illuminate when performing a "test" of the diagnostic lights. I tried hooking my scanner to the car, but it read no codes current or stored. Anyone know what it is & how to make it go away? Thanks.
RE: Oil Sensor Light
The low oil light, or the oil service light - the one that tells you when its time to change the oil?
Do you have a vag-com scanner, or a generic scanner? If its vag-com, you can reset the service interval with it, if not, you need to do it thru the clock/odo buttons on the cluster. |
This is a yellow light that illuminates in the same location as the low fuel or low washer fluid light. It is a picture of the "oil can" with the word sensor. It typically takes 5-10 minutes of driving or run time for it to illuminate. It is frustrating more than anything. Any help as to how to make it go away would be greatly appreciated.
I'll have to think on that....
I'll get back to ya. |
