OK now i got CELS
p1602 terminal 30 voltage too low----this one has me stumped
p1287 n249 open circuit p0411 SAI incorrect flow 17748 p1340 intermittent-----this one has me stumped |
RE: OK now i got CELS
p1602 terminal 30 voltage too low----Cant find much on this. SOmething isnt getting enough volts.
p1287 n249 open circuit needs a resistor p0411 SAI incorrect flow resistor might be on wrong lines causing above 17748 p1340 intermittent-----this one has me stumped The cam tensioner and timing belt are reading differnt... i know, you dont want to hear that. [:o] |
ya but that p1340 should be a wiring issue now...it says intermittent...it never said that before...and intermittent problems are usually electrical...
most say sensor or off align. Since you just redid it, im more leaning toward the later
Sorry for not contributing to the thread, but Cincy, are you an audi mechanic or something?
No, but i play one on TV
ORIGINAL: cincyTT No, but i play one on TV Ah, I knew I seen you some where. Thanks. |
ORIGINAL: cincyTT most say sensor or off align. Since you just redid it, im more leaning toward the later |
Is it safe to say your timing belt is off a tooth or two and you advanced your timing? Maybe that's why she feels stronger on the road now!
Thats what he just fixed, it being off a few teeth.
Ryan, i hope you are right. |
