Parallel port in hatch?
Old May 25, 2008 | 12:57 AM
TK_Fulgore's Avatar
Default Parallel port in hatch?
to start with, i have an '01 225Q
i seem to have a port that looks likea printer's parallel port (old style on computers) inside the hatch. it is inside that little door where you open to remove the tail light (left side). anyone know what this is? it says "G 50059" on it and "ABS" just below that (ABS referring to the type of plastic, i know, since the plastic pieces in most carsare ABS plastic).
i called up my father earlier, andhis '02 doesn't have this plug/port.
also, an unrelated question, but when you get chipped (going to do APR, since there's a place 10min away that is recommended on APR's website, $500) does the mod go away when you disconnect the battery/lose power to the ECU? explain this for me, if you could. Thanks! oh, picture of the plug/port:
Old May 25, 2008 | 01:01 AM
cincyTT's Avatar
I'm make believe
Default RE: Parallel port in hatch?
Not sure what that plug is, but a chip is like saving a Word doc on your PC. When you unplug that PC, the files are still in there.
Old May 25, 2008 | 01:02 AM
TK_Fulgore's Avatar
crap, how do i add pictures? i uploaded them before i made the thread but they're not showing up... here:
Old May 25, 2008 | 01:04 AM
chris's Avatar
I saw the same thing in my car, in the same location, when i replaced some of my brake light bulbs. I drive a '00 180 AWD.
TK_Fulgore's Avatar
thanks on the chip deal, i figured the remap got stored in the ECU's flash memory, but i wanted to make sure.
Old May 25, 2008 | 02:42 AM
TK_Fulgore's Avatar
if i come back to this thread when i get off work Monday afternoon, and there is no answer to the plug inquiry, i will ask the stealership what that sucker is. chris, i'll let you know.
Old May 25, 2008 | 03:17 AM
Murderface's Avatar
I'm not sure exactly what it is, but some have suggested it has to do with the nav package, which makes some sense I think.
Old May 25, 2008 | 03:22 AM
TK_Fulgore's Avatar
i have the nav and so does my dad, but his doesn't have the port.
Old May 25, 2008 | 04:09 AM
.clipse's Avatar
SoCal Crew Member
^ ya know, i always wondered what that port was. and yes, it does look like an old LPT-1 port.
someone please find out!
Old May 25, 2008 | 09:27 AM
XCLR8TT's Avatar
It's part of the handsfree phone setup that came as an option on the 00's and early 01's.
