Please help
Old Oct 13, 2007 | 01:45 PM
Stolzer Vater's Avatar
Default Please help
I left out for work this morning and my 01 TT 1.8 Quattro stuttered and the check engine light came on. It didn't stall, it idles fine. I wasonly about 3/4 of a mile from home so I just limped it back. I turned it off and it started back up like nothing was wrong but the check engine light stays on and it stutters whenI give it anythrottle.Does this sound likethe mass air flow sensor?It doesn't giveanycharacteristics of being the timing belt, but I'm not a pro. Any ideas would be greatly appreciated.
Old Oct 13, 2007 | 01:49 PM
randomloginname's Avatar
Default RE: Please help
you could temp disconnect the maf and see if it helps. could also check plugs. if you can pull any codes from a local shop or auto supply spot, there are links on here that will give some more info. did you happen to give it crappy gas or wrong octane?
Old Oct 13, 2007 | 01:55 PM
Thanks, The gas is fresh 93 oct. I'll try the disconnect and see what it does.
Old Oct 13, 2007 | 03:16 PM
XCLR8TT's Avatar
Drive over to your nearest Autozone... they'll read your codes for free. Post them here and we'll try to help with the diagnosis.
Old Oct 13, 2007 | 03:59 PM
Cool [sm=smiley20.gif]I'll do that tonight and post up what they find.
Old Oct 13, 2007 | 04:14 PM
theTTkid's Avatar
my money is on a bad coilpack(s).. is yours chipped?
