Question for the Vortexers.
Old Jan 23, 2007 | 03:37 PM
DenimTT's Avatar
Default Question for the Vortexers.
Theres an 05 GTI with a 1.8 on the lot. I've already looted the sirius Starmate-R setup out of it. It also has a Samco TIP, and P-Flo intake(not my favorite but better then the stock airbox).
I think I can convince the Used car Sales Manager to let me swap the TIP out for my stock one under the premise of it being easier to sell a car that hasnt been worked over. The question is does the TT airbox fit an 03 GTI so maybe I can grab the P-Flo too? Its hard to tell just looking at it, but the placement is identicle. I wont be wholly disappointed if its not a possibility as I'd rather have a VTDA, but wont argue with a free intake if its possible.
I'd post up on Vortex myself, but am still waiting out the registration. Any kind of help is appreciated.
Old Jan 23, 2007 | 04:28 PM
MeanAudiA6's Avatar
Default RE: Question for the Vortexers.
i signed up on vortex yesterday and its been working fine for me. thats odd that you cant log-on
Old Jan 23, 2007 | 05:19 PM
cincyTT's Avatar
I'm make believe
the intake will fit ANY 1.8t fwd car regardless. As for the tip it would have to corispond to you model year. For instance if you have a atc you need a awd code. so if you have a 02 and on tt it should fit you car fine.
Old Jan 23, 2007 | 10:05 PM
DenimTT's Avatar
I cross checked the part numbers on Neuspeed and Samcos respective website and since they matched up I went ahead and started snagging parts.
The OEM airbox from a 2001 AWP TT does in fact fit a 2005 GTI, and I now own a P-Flo.
The Turbo Inlet is a little different. Same part number but apparantly theres a metal neck off the turbo inlet that connects to the stock rubber hose that has to be unbolted from the turbo housing to mount the Samco Hose. So I have my rubber Inlet out, and if the GTI is still there when my car is on the lift for the waterpump/T-Belt job I'll go ahead and unbolt the OEM metal inlet piece and snag the TIP then. If we sell the GTI before that point, Ill just have to order one.
It would be a shame as the one in the GTI is blue and would be a freebie andeverything. But, hey, I got the expensive part already (plus I swapped my 6 year old MAF for a newer 2005). My job RULES! Free parts are great.
Old Jan 23, 2007 | 10:22 PM
DenimTT's Avatar
Also on Samco's website theres several part numbers for silicone turbo plumbing kits for theVW's AWP engine code from 5 to 7 pieces (Golf, Beetle, Jetta)
Any ideas on how many, if any of these hoses might be transferrable to the TT AWP and which would be the best platform to pick them from?
Just looking for more options on the poor neglected 180's. Then again, maybe I'll just get the $200 intercooler core from ECS and use some of the universal parts samco offers to make my own plumbing.
[edit] Plus my T-Belt kit shipped today and is scheduled for a Friday delivery so I'll have my car back this weekend after two long months.
Old Jan 23, 2007 | 11:52 PM
cincyTT's Avatar
I'm make believe
if you have a awp any 2002+ gti/jetta should fit. THis will make your life easier.
1.8t Engine Codes
US Market Volkswagen
2000 Golf/Jetta: AWD
2001 Golf/Jetta: AWW
2002+ Golf/Jetta: AWP
1997-1999 Passat: AEB
1999-2001 Passat: ATW
2001 Passat: AWM
2002-2004 Passat: AMB
1999-2000 Beetle: APH
2001+ Beetle: AWV
2002 Beetle Turbo S: AWP
US Market Audi
1997-1999 A4: AEB
2000 A4: ATW
2001 A4: AWM
2002 A4: AMB
2000-2001 TT 180hp: ATC
2001-2004 TT 180hp: AWP
2001-2002 TT 225hp: AMU
2003-2004 TT 225hp: BEA
Old Jan 24, 2007 | 12:37 AM
DenimTT's Avatar
Cool list. The problem is Quattro on the 1.8T is unique to the Audi platforms, which may provide interference with using parts off other cars(downpipes, and plumbing and such). Even the differences between the AWP and AMU are pretty staggering.
I dont mind experimenting, but I dont mind checking to see if anyone else has tried any of my ideas first. Good news is I'll get to cross reference plenty of applications as I run across them.
Can anyone with the Samco TIP on a 180 verify having to unbolt a metal tube from the turbo housing to connect the new hose? I'm referring to the piece that connects directly to the rubber flex hose via a spring clip.
[edit] Nevermind, a little browsing on Ebay and I found the metal inlet, held to the compressor by a single bolt. Definitely looks to be easier to get to from underneath.
Old Jan 24, 2007 | 03:41 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: DenimTT
Well the ko3, ko3s, and ko4-2X all have differnt size inlets. So you would have that problem well before hitting any part of the transfer case. That why the fwd's are made for all the same model years, ie 2000 atc - awd and so on.
Old Jan 24, 2007 | 03:49 PM
DenimTT's Avatar
Looks like Im snagging a freshly rebuilt T3/T4 (IHI variant) off an SVO Mustang. No shaft play. .57 COMPRESSOR WHEEL TRIM, .50 A/R COMPRESSOR, .63 A/R TURBINE. capable of 530hp or so. 25 psi in the sweet spot of the map.
I may have a monster on my hands.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
