quick brake question
Old Sep 21, 2007 | 01:22 AM
proxeyed's Avatar
Default quick brake question
Okay so Ive been expecting to change my brake pads for awhile, hopefully not rotors. Anyway, I did about 100 miles of a canyon run today, and now I definately need pads. ECS tuning has HAWK HPS pads, 4 for $90. These pads do not have wear sensors. Im not sure if I have wear sensors or not, but if I did, can I use these anyway without the wear sensor? Also, the "00 Quattro, has the 288mm or 312mm rotors right? Thanks.
Old Sep 21, 2007 | 01:31 AM
cincyTT's Avatar
I'm make believe
Default RE: quick brake question
If you have a '00, you dont have wear sensors. You can check the lip on the rotor and if its not to big, you can have a brake shop resurface the rotor for you for cheap. And they are 12.3"/312mm
Old Sep 21, 2007 | 01:38 AM
proxeyed's Avatar
The lip isnt that big at all. Thanks.
Old Sep 21, 2007 | 01:50 AM
cincyTT's Avatar
I'm make believe
Sounds like your good then. BTW, you can get some nice pads for the street for far less than $90. Head over to getcoolparts.com or tirerack also to see what they offer.
Old Sep 21, 2007 | 01:55 AM
proxeyed's Avatar
Ill check it out right now, front and back for $90, or front only? I plan on replacing them all. I eventually plan on attempting auto-x, but not until I have the $$. How much did you get your Wilwood kit for?
Old Sep 21, 2007 | 02:12 PM
cincyTT's Avatar
I'm make believe
I got my wilwood kit for under $1k and sold my stock brakes for $250, so all in all, i spent ~$750
Old Sep 21, 2007 | 02:24 PM
ouTTie914's Avatar
Be careful if you're going to get rear discs.
The size for 180 quattros and 225 quattros are very different!
2000 180 Quattro
Front: 312 x 25
Rear: 239 x 9
EBC makes a nice slotted and cross drilled rear disc for the 180 quattro.
Not too expensive either.
tofast2belast
Jul 9, 2013 07:01 AM
jwd2a
Jul 4, 2010 02:21 PM
Mr. Phil
Oct 30, 2009 05:31 PM
exequiel3k
Oct 13, 2009 06:45 AM
captcaos2002
Dec 1, 2007 05:24 PM
