Random ABS/ESP dash lights
Old Feb 3, 2007 | 09:55 PM
timbo108's Avatar
Default Random ABS/ESP dash lights
First off I tried searching but couldn't find a match.
My 2001 6 speed Quattro randomly studders and lights up the ABS and ESP dash lights. When I turn off and on again, lights are one. There appears no pattern. I just picked up a Equus/Innova 3100c code reader hoping to catch a DTC number. Will I harm anything if I plug into the OBDII port while the car is still running? The code reader says the car needs to be off, them in the run position. Problem is, when I turn the car off, no DTCs show up on the reader.
Somewhere I read about a faulty ABS sensor problem that had to due with yaw. Am I on the right track? If I do catch a code, is there a good list of Audi DTCs?
Thanks in advance
Old Feb 3, 2007 | 11:08 PM
achTTung's Avatar
Default RE: Random ABS/ESP dash lights
Shouldn't be a problem to check for codes while its running, I've used vag-com while on the road, checked and cleared codes, and reset service interval lights.
Old Feb 4, 2007 | 04:51 AM
Roadster's Avatar
this happened to me soon after i purchased my roadster. took it to the dealer and they replaced a "longitudinal" sensor in my traction control. took care of the problem.
Old Feb 4, 2007 | 10:42 PM
liTTo's Avatar
yeah, longitudinal acceleration sensor. i had the same problem, got the part for under $90, 1STVWparts.com and changed it out, no more problems.
Old Feb 5, 2007 | 04:10 AM
Roadster's Avatar
yeah, i used to never go to a dealer...now i know why everybody hates them! let's just say i paid plenty more! [:@]
Old Feb 5, 2007 | 11:35 AM
timbo108's Avatar
Default RE: Random ABS/ESP dash lights- Thanks for the help
Thanks for confirming my suspicions. Anyone have the OEM part #? Is it something a decent shade tree mechanic can do ? I'd rather do it myself instead of a dealer. None within 50 miles of here.
Old Feb 9, 2007 | 10:52 PM
timbo108's Avatar
Maybe there's more to this. It's more frequent now and when it does go, it spasms and seems the power dies completely for a second (headlights blink, instrument needles zero, stereo pauses etc), then back up again with the yellow ABS and ESP symbol on along with a flashing red Brake. Tonight I was driving home and when I flipped on the high beams, it went into the funk.
Does this sound familiar to anyone else ? I know it need it dealer or Vagcommed to catch a code. My code reader Equus 3100c doesn't pick anything up.
Old Feb 10, 2007 | 02:25 PM
XCLR8TT's Avatar
Check your battery. These cars are very sensitive to low voltage. With everthing shut off you should see 12.5V minimum across the terminals.
nize
Jun 21, 2013 01:16 PM
Jasonb61
May 23, 2010 09:00 PM
blockp
Jan 30, 2008 01:04 AM
rmac.cab
Oct 17, 2007 02:21 AM
alan93
Jul 6, 2007 09:49 PM
