Rear Toe Angle
Old Aug 22, 2008 | 09:32 AM
Durty's Avatar
Exclamation Rear Toe Angle
2 days I did my alignment and got a little surprise.
Rear toe is way out of spec. Audi says 0.05 degrees is ok
Rear left @ +0.25 and rear right @ +0.55
this is NOT GOOD at all. the alignment guy looked at the rear control arms and determined that they are not adjustable, said something along lines of where it bolts to sub frame it has a 4 bolt square setup with no room to move around or pivot for Toe in/out adjustment.
Any1 got any info on how i can correct this. i spoke with ECS Tuning and TT Stuff . They both indicate that only camber adjust is available.
any thoughts?
Old Aug 22, 2008 | 11:36 AM
hotgrass's Avatar
do you have a print out that you can post?
Old Aug 22, 2008 | 01:06 PM
Durty's Avatar
ill try to scan the report today
front allignment is within spec. rear is out of spec
nick_goldie
Oct 16, 2008 11:58 PM
elvisb
Apr 9, 2007 07:26 PM
///a4///
Nov 10, 2006 04:14 PM
onepoint8tee
Sep 6, 2005 04:24 AM
trailboss
Dec 29, 2004 04:42 AM
