Service Light/Autozone
Old Mar 12, 2007 | 10:13 PM
Indiepunk's Avatar
Default Service Light/Autozone
So I've been getting this service light on my display and tookthe TTto Autozone to see what was wrong. I figured it may tie into my boost problem. After the guy hooked up his device to my port I waited and......... nothing was wrong. I'm working on the vag solution and that should get here soon enough. In the meantime I figured I'd see if anyone has seen anything like this before?
Old Mar 12, 2007 | 11:24 PM
cary12's Avatar
Default RE: Service Light/Autozone
Is it a CEL or is it just the light that says "Service"? If it just says "Service", then it's just time for the scheduled service.
Old Mar 12, 2007 | 11:48 PM
cincyTT's Avatar
I'm make believe
service light is just a suggestion.
cel needs taken care of.
mine has said service for along while and im just to lazy to clear it. There are ways to clear it without vagcom that can be found in a search.
ps nice sig ^ answer... as much as your dv!! NONE!!
Old Mar 13, 2007 | 12:10 PM
timbo108's Avatar
Found the manual reset method as follows
CLUSTER METHOD:
- Switch ignition off
- Press and hold trip reset button, Turn key on
- Central display will show "SERVICE in XXX" or "SERVICE"
- Release button
- Turn the clock adjuster **** counter-clockwise or clockwise, this will reset the display "SERVICE in XXX" Adjust to desired interval
Old Mar 13, 2007 | 12:33 PM
Indiepunk's Avatar
It took a couple tries and a variation on the technique to get it to work. I was trying the clockwise/counter-clockwise part but it was not working. I believe I pushed in the button and it gave me the service in 9300 miles. So this was a success. Thank you Timbo108.
I did notice when I was doing the reset incorrectly that it gave me a bunch of options when I held the button in. It went by so fast that I can't remember all of the pictograms. Has anyone seen this before?
ou2mame
Feb 5, 2009 07:08 PM
antonio_A6
May 4, 2008 08:19 PM
eldrego
Oct 4, 2007 10:51 PM
TurboQuattroPwr
Jul 26, 2006 06:52 PM
jjmorgan71
Jun 25, 2006 01:35 PM
