Servicing
I recently had the 40k servicing done at the dealership. However, I just had the 2001 TTQC 225 shipped to Korea. There are very few dealers here. Which means that I will do most of the servicing in the next 2 years myself. anyone have a link to some servicing info? ie: differential lubrication (fluid, grease); manual transmission case lubrication (fluid etc); Haldex fluid; brake fluid; power steering fluid; any other fluis I forgot... etc etc
Also, I recently upgraded to EBC Red stuff pads (all four) and "Power Slot Cryo" slotted rotors (front).... I was thinking of replacing lines with steel braided line but havent ordered them YET. Want to know the difficulty of install and pros and cons prior to purchase. Thanks
Code letters, allocation, transmission ratios, capacities
Rear final drive
02D
Code letters
EHR
EUK →Note
FGT →Note
Manufactured
from
to
10.98
10.99
11.99
02.01
02.01
08.01
Allocation
Model
Audi TT 1999 >
Audi TT 1999 >
Audi TT 1999 >
Engine
1.8 ltr. - 132 kW
1.8 ltr. - 165 kW
1.8 ltr. - 132 kW
1.8 ltr. - 165 kW
1.8 ltr. - 132 kW
1.8 ltr. - 165 kW
Ratio: Z45: Z67
Front/rear bevel gearing
17 : 27 x 27 : 17 = 1.00
Capacity in final drive
1.0 litres
Specification
Gear oil G 052 145 A SAE 75W-90 (synthetic oil)
Capacity in Haldex coupling
0.42 litres
Changing capacity in Haldex coupling
0.25 litres
Specification
High performance oil for Haldex coupling G 052 175 A1
Drive shaft flange Ă˜
100 mm
100 mm
100 mm
Allocation: gearbox type
02M/02Y four-wheel drive
1)
Modified control unit for Haldex coupling (fitted with ESP)
2)
From 02.01 change of materials used for Haldex coupling
Rear final drive
02D
Code letters
FWS →Note
Manufactured
from
to
09.01
Allocation
Model
Audi TT 1999 >
Engine
1.8 ltr. - 132 kW
1.8 ltr. - 165 kW
3.2 ltr. - 184 kW
Ratio: Z1011: Z1213
1.0 litres
Specification
0.42 litres
0.25 litres
Specification
100 mm
02M/02Y
02E four-wheel drive
3)
From 09.01 modified Haldex coupling housing and modified cover for Haldex coupling oil reservoir
Wow.. thank you. that is quite possibly the most difficult thing I've tried to read on here. lol
I meant more along the lines of capacity and fluid type. Sorry... I'll bookmark this though as it looks like it has some serious detailed info on it. Thanks again
