should I get a 4 pressure regulator
Right now all of have is an APR chip, samco hose inlet, 3" dp, forge fmic, high flow cat. I raised my boost to 21psi, should i get a 4 bar pressure regulator, do I really even need it? What about bigger injectors, will that help any? With the stuff I have now should I get it tuned or would it be a watse of money?
RE: should I get a 4 pressure regulator
only if you have the bigger maf housing from modshack should you go with a 4bar FPR would be a waste of money without it
