Sluggish boost gauge?
Old Feb 27, 2008 | 05:21 PM
MalachiConstant's Avatar
Default Sluggish boost gauge?
All,
I recently installed an AWE boost gauge in my 02 225. I have no other mods, just prepping for a chip eventually. I have one question: Is my boost gauge supposed to be sluggish? By sluggish I mean that the needle never moves quickly in any direction. At idle its at around 20-22 Hg, and even when I floor it, it just slowly creeps up past the 0, and into the lower end of boost. But by the time I have to shift it hasnt even reached 10lbs. Any thoughts?
Old Feb 27, 2008 | 05:27 PM
achTTung's Avatar
Default RE: Sluggish boost gauge?
Thinking the line is kinked, or you hooked it up someplace weird. It should be quite responsive.
Should have Tee'd into manifold vacuum. Easiest place to do that is from the fuel pressure regulator's vac line. Believe on the 225 it starts near the throttle body and snakes along to the opposite end of the TB to the regulator, which looks like a 1" metal canister on the end of the fuel rail.
I haven't even considered installing a boost gauge on my 225 yet, so I don't really have a mental picture of the hose routing.
Old Feb 27, 2008 | 05:29 PM
Red_sapphire89's Avatar
sounds like you have a kinked line or a leak!
Did you "T" it into the fuel pressure regulator? Check your line and if you didnt use the fpr to "T" it into id reccomend it as the source
Edit i didnt repeat the above we posted at the same time lol
Old Feb 27, 2008 | 05:42 PM
achTTung's Avatar
pics > words, so it'd be ok even if you did repeat what I said. ; )
Old Feb 27, 2008 | 05:48 PM
scoTT la rock's Avatar
i have the AWE. that needle should pop up real quick bro...
Old Feb 27, 2008 | 05:54 PM
Ok thanks guys. I did in fact "T" it to the FPR. I checked from the firewall forward for kinks or bends and couldnt find any, but I have to look from the firewall back into the cabin now to see if there is an issue there. Thanks for the help again, much appreciated.
Old Feb 27, 2008 | 06:46 PM
themysteryman83's Avatar
From idle to full throttle the needle takes maybe 3/10ths of a second to get where it needs to go on my VDO. If you're using that crappy nylon tube that the kits come with get rid of it and get some proper vacuum line (rubber or silicone). The nylon stuff is very prone to kinks and leaks.
Old Feb 27, 2008 | 07:19 PM
ORIGINAL: themysteryman83
The AWE kit came with normal black rubber vacuum tubing so I don't think its an issue. Mine takes the full rev range and it still doesnt get to where it needs to go.. on the up or downswing on the needle its slow regardless.
Side question: About where should it be going to boost wise? I was thinking around 16-18 psi? The highest I have gotten it is 10, but if there is a kink or leak, the reading is bad regardless.
Old Feb 27, 2008 | 07:24 PM
11psi stock i think im not 100% lol but i am 100% you have a leak or kink or clogged line
Old Feb 27, 2008 | 07:26 PM
cincyTT's Avatar
I'm make believe
180 = 11psi
225 = 1bar
to4xxx
Jun 8, 2012 11:56 AM
elrocha69
Mar 24, 2009 11:23 PM
slackerscott04
11
Feb 21, 2007 04:46 PM
Soley4pres
Jan 31, 2007 04:08 AM
s4me
May 18, 2005 08:39 PM
