Smoother 1st to 2nd shift
Old Jul 26, 2008 | 06:57 PM
Warhawk's Avatar
Default Smoother 1st to 2nd shift
When im shifting from first to second, its 90% of the time fairly jerky when im doing this, what am i doing wrong while driving? Also, for daily driving, around what rpm should i be taking off in first in? For the most part the rest of the gears are fine, 1-2 just sucks.
Old Jul 26, 2008 | 07:00 PM
.clipse's Avatar
SoCal Crew Member
Default RE: Smoother 1st to 2nd shift
^ there really isn't a specified rpm to release clutch from 1st gear. you just gotta smooth it out and "feel" it from idle
Old Jul 26, 2008 | 07:21 PM
achTTung's Avatar
+1
but i'd suggest taking a split second longer to roll off the throttle before shifting. no need to slam thru the gears.
Old Jul 30, 2008 | 12:00 AM
GHETTOxWHITExBOY's Avatar
i noticed my tt does that too sometimes.......is it cuz the trac. cont. ???
Old Jul 30, 2008 | 12:16 AM
cincyTT's Avatar
I'm make believe
If you keep the rpms around 3k, it will be smoother andalso whatssaid above.
Traction control has nothing to do with this
Old Jul 30, 2008 | 11:30 AM
kwaskow's Avatar
SAme observation, but much smoother if I run out 1st a bit longer, up past 3K
Old Jul 30, 2008 | 02:07 PM
Warhawk's Avatar
Yeah i noticed that too, if i shift at roughly 3 grand it is a hell of a lot smoother
Old Jul 30, 2008 | 10:09 PM
i like to shift at 6500 !!! lol
KingWulfgar
B7 Models
Jul 24, 2014 09:03 AM
SHADETREE81
Jan 7, 2012 10:07 AM
manhattanprjkt83
Jun 23, 2008 01:47 PM
masterforu2nv
Aug 14, 2007 02:41 PM
starting...
Feb 7, 2007 04:15 PM
