Still running lean....
Old Nov 29, 2011 | 01:31 PM
IronCobra53's Avatar
Default Still running lean....
Hey guys my 03 tt fwd is still throwing a code for running lean, no CEL but still has a code for running lean, I cleaned my maf already, but I can tell its running leaner thn usual because my exhaust tip isn't nearly as black as usual n it doesn't pop/ backfire like it used to (im basically straight piped, n my tt always popped with this exhaust so im assuming it's normal) im replacing the fuel filter soon to see wht happens plus there's 75k one the stock one anyway, so any ideas?
-Rich
Old Nov 29, 2011 | 02:12 PM
cincyTT's Avatar
I'm make believe
Vac, exh, and boost leaks all can cause this. Same for a bad primary o2
Old Nov 29, 2011 | 07:27 PM
rpetral0's Avatar
Took my a while to find my van leak last winter, there was a massive hole in a plastic assembly underneath the manifold, pain in the *** to find.
Old Nov 30, 2011 | 10:14 AM
According tommy gauge my vac pressure is the same as always, but ill still check, also ny new downpipe relocated my o2 sensor farther downstream, but the problem started awhile after I installed it, n it ran great for tht time with the downpipe
Old Nov 30, 2011 | 10:24 AM
cincyTT's Avatar
I'm make believe
What dp are you running?
Old Dec 1, 2011 | 11:35 AM
Ebay 3" with testpipe section not sure of the brand id hve to find the receipt
Old Dec 1, 2011 | 01:02 PM
cincyTT's Avatar
I'm make believe
If you are using their gaskets, that could be an issue. They are pretty bad and could be leaking already.
Old Dec 2, 2011 | 03:44 PM
I think I did use they're gaskets I covered Thm in copper sealant though, ill check Thm tonight
Vezon
Dec 27, 2012 04:39 PM
CTFRunN3r
Apr 6, 2009 01:27 PM
sixfiveoh
Mar 1, 2008 05:40 PM
auditt225
Jun 25, 2007 03:44 PM
brent78
Nov 19, 2006 05:50 PM
