View Poll Results: A poll
Screw it play some Madden and let you figure it out
0%
Leave it up to the profrssional
0%
Voters: 6. You may not vote on this poll
TT door removal DIY
TT door removal DIY
So I pulled apart the TT so I could install new speakers this weekend. I put the TT back together but once I got on to AF this morning I realized I should share some knowledge with you guys if you want it.
RE: TT door removal DIY
a DIY is always welcome you might know of some cheats while you did it but hopefully this data will help you do the DIY
Overview
1-
Door subframe
Note[/align]
Before removing, use a fine felt-tip pen to mark the position of the subframe on the door in a suitable place, e.g. on the collar of the bolts and nuts.
q
Removing:
ā
Remove door trim .
ā
Unplug wires from door subframe and unclip.
ā
Loosen hexagon nuts .
ā
Unscrew hexagon bolts and hexagon nut
ā
Lift out door subframe.
q
Installing:
l
The front door must be adjusted before installing door subframe.
ā
Insert door subframe into door, align with markings applied before removing and secure loosely.
ā
Adjust door subframe .
2-
Motor for window lifter
q
Removing:
Note[/align]
The window lifter motor can be installed or removed with the motor and door window in any position.
ā
Remove door trim .
ā
Unscrew Torx bolts and detach motor.
q
Installing:
ā
Tighten bolts to 3Nm+0.5 Nm.
ā
When installing a new motor you have to adapt the force-resistance characteristic .
Note[/align]
t
To activate the automatic open/close function of the window lifters with motor installed and wiring attached:
t
Switch on ignition.
t
Move door window upwards to limit stop and then release switch.
t
Then pull switch in position āwindowclosedā for approx.2seconds.
t
The open/close function has now been activated.
3-
Torx bolt,3Nm
4-
Hexagon nut,30Nm
5-
Front door
6-
Pop rivet
7-
Support
q
To remove, drill out rivet heads and drive out rivet stems.
q
After the door subframe has been installed and adjusted, push up adjusting wedge so that support makes contact between door and guide rail .
8-
Hexagon bolts,25Nm
9-
Hexagon nut,30Nm
Adjusting the support
l
Door subframe adjusted.
ā
Push adjusting wedge -3- of support -2- upwards to the limit stop.
l
When correctly adjusted, adjusting wedge must make contact between door -1- and guide rail -4-.
[IMG]local://upfiles/12092/3B60A9BAF8B548EDA09ED3D449404B91.jpg[/IMG]
[IMG]local://upfiles/12092/319DFC1E17FC4738BED6BDD275B2FB03.jpg[/IMG]
Overview
1-
Door subframe
Note[/align]
q
Removing:
ā
Remove door trim .
ā
ā
ā
ā
q
Installing:
l
ā
ā
2-
q
Removing:
Note[/align]
ā
Remove door trim .
ā
q
Installing:
ā
ā
Note[/align]
t
t
Switch on ignition.
t
t
t
3-
Torx bolt,3Nm
4-
Hexagon nut,30Nm
5-
Front door
6-
Pop rivet
7-
Support
q
q
8-
Hexagon bolts,25Nm
9-
Hexagon nut,30Nm
l
ā
l
Actually I wish I had that when I was pulling it apart. The only advice I got was find the torx screw and unscrew it, then lift. I was namely thinking of a door panel speaker install and door panel removal. No problem on killing the poll.
lots of stuff like that and a sod to find things when your taking them apart but here is a how 2 for others to look at
Removing and installing front door trim
1-
Door trim
q
Remove cap -5- .
q
Unscrew bolt -4- (1x).
q
Unclip inner and outer transition pieces.
q
Lift door trim approx. 20 cm out of door shell.
q
Disengage Bowden cable for interior door handle .
q
Unplug connectors .
Pads -3- (7x) for fasteners must be clipped in on installation.
2-
Sleeve
3-
Pads
4-
Bolt
q
Tightening torque 7.5 Nm
5-
Cap
Disengaging Bowden cable
ā
Pull Bowden cable -1- out of guide -2- and disengage.
Note[/align]
On installation, make sure hook -3- is facing upwards.
Unplugging connectors
ā
Unplug connectors at Item no. -2-.
Removing cap
ā
Guide mandrel -2- (Ć max. 2 mm) through hole on underside of switch trim.
ā
Use mandrel -2- to press lug -3- slightly upwards and at the same time turn cap -1- in direction of arrow.
ā
Detach cap -1-.
[IMG]local://upfiles/12092/EC9F378CA54D4DFEB1ACD115E57D4F72.jpg[/IMG]
[IMG]local://upfiles/12092/1F41C12B8AF545959C8DAAA08118CA90.jpg[/IMG]
[IMG]local://upfiles/12092/417585930A0A4E17921D20B8EAC02068.jpg[/IMG]
[IMG]local://upfiles/12092/3766B9371079449CB03A51DC0DBF65C7.jpg[/IMG]
1-
Door trim
q
Remove cap -5- .
q
q
q
q
q
Unplug connectors .
2-
Sleeve
3-
Pads
4-
Bolt
q
5-
Cap
ā
Note[/align]
ā
Removing cap
ā
ā
ā
Detach cap -1-.
Removing and installing rear side trim
1-
Side trim
q
Remove rear seat bench and backrest .
q
Remove outer seat belt anchorage point .
q
Remove striker pin of rear seat backrest .
q
Starting from top rear, unfasten side trim -1- from clips -2- (8x).
2-
Clips
Removing outer seat belt anchorage point
ā
Open cover of panel -1- at top in direction of arrow.
ā
Unscrew bolt.
ā
Tightening torque 55 Nm
Removing striker pin
ā
Unfasten nut -2-.
ā
Screw out striker pin -1-.
ā
Adjust striker pin on installation.
t
Luggage compartment side trim -4-
t
Threaded plate -5-
t
Side trim -6-
[IMG]local://upfiles/12092/09C7027330AB40FC830127A911C029A6.jpg[/IMG]
[IMG]local://upfiles/12092/A4FB8C56B1A14F64A5A6DE3EE5915CBA.jpg[/IMG]
[IMG]local://upfiles/12092/0C2815E6E1764EF79990246DD2525EBB.jpg[/IMG]
Removing storage compartment and cover at rear side trim
ā
Remove rear side trim .
ā
Press fasteners at top of side trim and disengage storage compartment at bottom.
ā
Detach storage compartment.
ā
Use flat screwdriver to prise out bolt cap -1- (2x) at top and bottom -arrows-.
ā
Unscrew bolts -1- (2x).
ā
Fully open cover -2- and detach cover outwards.
On installation, make sure spring has sufficient pre-tension.
ā
When fitting, guide shaft -3- with āUā-shaped edge -4- into lug -5- of cover.
# forgot the pictures[:-]
[IMG]local://upfiles/12092/F5DAF65510B6407AAD16B77BF5C031A1.jpg[/IMG]
[IMG]local://upfiles/12092/FE915D17C04B42C99452CC958396C597.jpg[/IMG]
[IMG]local://upfiles/12092/8581FD054F5140DF92A909DAC38C87A9.jpg[/IMG]
