tt ko3-ko4 help
Old Jun 10, 2007 | 10:57 AM
oris's Avatar
Default tt ko3-ko4 help
Ok, I have a 2000 TT with the stock KO3 turbo I would like to install a KO4 turbo, I want to kown what I would need to do the install. I also have a Giac solder-in chip that was installed about 5 years ago with the first owner of the car, the car runs about 17lbs of boost, would I also need a software upgrade or is what I got go enought?
Thanks for the help!
Old Jun 10, 2007 | 11:03 AM
cincyTT's Avatar
I'm make believe
Default RE: tt ko3-ko4 help
ko4-001 is a direct install. It is smaller than the ko4 in the 225 and is only good for about another 15-20 over a ko3. It will however hold boost longer than a ko3. You can leave your chip in place, but a upgrade wont cost to much.
for a ko4-2x from a 225 is not a bolt on. you have to get a new manifold along with other parts. go to www.pro-imports.com. they have full kits available there. good for abouth ~40hp
Old Jun 10, 2007 | 11:24 AM
oris's Avatar
Thanks, also with the KO4-2x would I need to change my software or is it fine to use? What software file from Giac would you recomend?
Old Jun 10, 2007 | 11:33 AM
cincyTT's Avatar
I'm make believe
you will need 225 injectors or some 380cc and sw written for it. Just ask the closest dealer what they can get for you.
Old Jun 10, 2007 | 12:34 PM
225tt's Avatar
Or just go Big Turbo!
Old Jun 10, 2007 | 03:19 PM
cincyTT's Avatar
I'm make believe
for about the same cost as a ko4-2x, you can get a t3s60 or 50trim setup and get real power.
Old Jun 10, 2007 | 03:21 PM
225tt's Avatar
Yep yep, he knows his stuff!!!!
Old Jun 10, 2007 | 09:44 PM
theTTkid's Avatar
i wish i was cincy smart... shoot[]
Old Jun 10, 2007 | 09:52 PM
cincyTT's Avatar
I'm make believe
lol, dont know where that came from
