UnEven Tire wear
Old Apr 15, 2009 | 04:43 PM
warranty225cpe's Avatar
doesnt achtung mean warning or caution?
Old Apr 18, 2009 | 09:47 PM
fireman9585's Avatar
I looked up ECS and they have a bushing kit for the front suspension. Is there a similar kit for the rear suspension, or is the front all I need? And is ECS the best source?
Old Apr 18, 2009 | 10:25 PM
XCLR8TT's Avatar
There is usually plenty of adjustment in the fronts to get back to spec. The rears however, leave little adjustment stock. If you aren't lowered you can get buy with a 1/2 set of K-Mac bushings or adjustable lower arms. Lowered you'll need a full K-Mac or 1/2 Kmac in the top bushing and adjustable lower arms. Skip the ground control kit or anything else for the front end unless you are trying to dial in some sort of an aggressive front camber.
I've got full K-Macs on the rear of mine with stock fronts.
Old Apr 20, 2009 | 02:08 PM
I'm a little confused. My car's not lowered, so you say I need a "1/2 set" of K-mac bushings. Can you explain for a novice, all be it a 58 year old novice? And where can I get the K-mac bushings?
Old Apr 20, 2009 | 03:16 PM
TTLayne's Avatar
Member
TTstuff has them. But if you dont want an alignment then you can just whip your car around more corners and the wear should even out lol. worked for me!
Old Apr 26, 2009 | 08:56 PM
sparky450r's Avatar
X2...how to know if we need half or full kit? I have 19" rims....not lowered.
Went to audi for an alignment and they are telling me the adjustment bolts are locked up and its gonna be a $700 fix (common issue). Im sure others have experienced this...it seems that a good mechanic could bust anything loose. I would sell this POS before i pay the dealer that much.
Old Apr 28, 2009 | 11:11 PM
Senater_Cache's Avatar
its not technically an alignment issue (yet!)
if your TT is lowered it will have negative Camber and cause your tires to wear aggressively on the inside, especially in the rear.
Adjusting the Camber (and maybe even Toe) with an alignment will fix the tire-wear, BUT, the 225hp TT does not have adjustable geometry in the rear and cannot have its Camber adjusted.
You will need either a Kmac kit on the bottom (for Camber) or adjustable lower control arms.
Otherwise dont waste your money on alignments as it will not fix the issue.
PS, Achtung means Attention, Caution or even Warning (in context)
Old Apr 28, 2009 | 11:49 PM
  #18
sparky450r's Avatar
Ok, one more stupid question....if a camber kit were installed would that also help out to straighten the toe? Do camber and toe go hand in hand, or are they two completely separate entities.
I know the difference in camber and toe, I was just wondering if I were to adjust one would it help the other....hope you get my drift.
Old Apr 29, 2009 | 09:38 PM
  #19
ttookool's Avatar
Toe and camber are not the same thing. camber is the angle the tire is oriented on the x-axis (excess - wears out the inside and excess + wears out the inside). When camber is off it will be a slow and smooth wear.
Toe is the arrangement on the y-axis. If you are toed out the inside will wear out soon as that part of the tire somes in contact with the road before the rest of the tire. The inverse is true for a toe in. Toe wear is not smooth and even but instead has a saw tooth shape and occurs very quickly and may cause noise issues if it is really bad.
Toe problems generally are from wear and tear from going over speed bumps and rough roads, and can be fixed by an alignment. If an alignment does not fix the issue and you state that you recently purchased the car, you need to have it CarFaxed as it may have been side swiped and the insurance company was too cheap to align the frame, in which case the dealer better pay to fix it.
Old Apr 30, 2009 | 06:00 PM
  #20
you guys are good! How hard is it to install the K-mac 1/2 kit? Should I have my mechanic install it?
