AudiForums.com
-   Audi TT (https://www.audiforums.com/forum/audi-tt-7/)
-   -   Valve cover leak affect boost? (https://www.audiforums.com/forum/audi-tt-7/valve-cover-leak-affect-boost-161069/)
phatboyfromla Dec 6, 2010 09:23 PM
I noticed my valve cover has a leak on the right hand side where apparently they are prone to leaks. By the half moon shape piece. Can this affect boost or just get oil everywhere? I'm asking because each time I do a leak test I remove the oil cap but this last test it wasn't removed and that's when I noticed the leak.
I'd like to replace it myself but after reading a few posts I have a feeling I'll break something else in the process. It's a 225. The previous owner did not maintain this vehicle. Hope you guys don't get tired of hearing from me. Thanks.
phatboyfromla Dec 17, 2010 04:00 PM
I'll just answer myself. Yes it does affect boost and probably why mine has gone to hell.
coachvtt Dec 20, 2010 01:32 PM
Yes it will affect engine compression! and you will get oil all over.
Get -r - fixed asap..
warranty225cpe Dec 21, 2010 05:18 AM
Really..? Well then im in trouble because mine vents to the ground
beachchair Dec 21, 2010 07:24 AM
If you really believe that, I'd like to see you do a compression test!
coachvtt Dec 21, 2010 01:19 PM
Ok! I stand corrected. Crack in valve cover will not affect compression?
I would like to know then as well.
phatboyfromla Dec 22, 2010 04:12 AM
Not compression. Vacuum/Boost. Not the same thing obviously.
