Weird question...lol
I think it would be hard to drive it in general, because the TT's pedals are much closer together then most cars. Also, the stearing wheel doesen't go in or up very far. I always drive with mine all the way in and up and I'm 5'11" 175 lbs. Just search autotrader and find one at a dealership to test drive.
My opinion is that you wont fit comfortably. You're right leg is going to be pushed left by the knee bolster making shifting awkward. The seat isnt going to feel very good because of the seat bolsters digging into your ***. When you sit, and with the seat back, I can guarantee your steering wheel will be pushed "in" and your arms will be too far from the steering wheel. If you move up, your stomach will be pressed into the bottom of the wheel.
I dunno man, it IS a small car. If you still want the car, you should try finding some flatter seats to swap in and removing the knee bolster triangles. That would give you a bit more room! Also relocated the battery to the rear right of the car and remove the rear left bumper dead weight to balance things out a bit.
Good luck!
Good luck!
ORIGINAL: ouTTie914
+1
No one can tell you your comfort level, except for you.
ORIGINAL: jakej
