Whats wrong this car???
Old May 11, 2009 | 12:05 AM
turbolove's Avatar
Member
Default Whats wrong this car???
For the past while my car hasn't been running to great. It use to bogg in almost every gear if i put a little pedal to the metal..... So i tried everything I can do myself.. Changed all the spark plugs, changed the 4 coil packs... changed my filter to a cone... cleaned my MAF sensor....even changed the the plug to the MAF.. still ran a little off but it deff ran a little better. After i spoke to my friends dad someone who knows alot about cars he told me to change my fuel filter which i did... also helped but now when im already driving and i step on it, it will always shake and lag then boost hard. Also first gear boost fully but i doesnt have any power its werid Can anyone help meee
Old May 11, 2009 | 03:54 AM
precision tt's Avatar
how much did it improve with all those mods, you make it sound like it did a lot and that is hard to diagnose. turbo cars have lag if you punch it off low RPM so that might be a problem. if that is not the case them i would blame it on a boost leak. for example if you are at 3000 rpm and you punch it it shouldnt lag if it does then it could be a boost leak from a hose or from a bad Diverter valve. that is my only valid diagnosis for power loss. there are few thing that will make you loose a lot of power when gunning it.
Old May 11, 2009 | 04:48 PM
MCPaudiTT's Avatar
You need a VAGCOM to properly diagnose your problem.
asalian
Sep 25, 2010 03:39 PM
newyorkgiants44
Jul 26, 2007 02:11 PM
shinnny
Feb 23, 2006 05:18 AM
auDi1.8TQ
Feb 17, 2006 02:39 AM
