Whats wrong PLEASE?
Im about to buy an Audi 2001 TT 1.8 however it has several problems. Its throwing a few codes and my question to the Audi gurus is do all these codes have them same problem? Meaning is there one main problem for all these??
P0441,P1296,P1136,P0301. Long definition . . . . . . . . . P0441 Definition EVAP system incorrect purge flow Explanition blocked vaopr canister cause faulty vent solenoid faulty purge control solenoid faulty fuel tank pressure sensor P1296 definition colling system malfunction explanition check cooleant level cause check ctss and circuit P1136 Definition Long term fuel trim add. Fuel B1 system too lean Explanation Failed MAF cause Low fuel pressure vacuum leak on engine failed HO2S Heated Oxygen sensor Bank1 P0301 Definition Cylinder 1 misfire condition Explanation Vacuum leak on engine cause ignition system fault fuel injector fault engine mechanical condition :eek::confused: Hopefully there is some common ground that is causing this im new and YES this is my first post hopefully not my last |
dont buy this car.
Replace the vacuum hoses from intake manifold, it sounds like a boost leak for one. try and find a VAG-COM to test the fueling componets and relays |
