Will this fit a TT
Old Mar 27, 2008 | 09:54 AM
Red_sapphire89's Avatar
Default RE: Will this fit a TT
I did they said they where unsure they passed the phone to two different guys[:@]
Old Mar 27, 2008 | 10:26 AM
WishIWasRWD's Avatar
I like the idea...
I drive both in the city and country.
Adjusting them on the go would be cool to be able to do.
Low in the city where I don't need the lights, and higher in the country where I don't have to worry about blinding people.
Or I could just set them in the middle and not waste $100 on something I really don't need.
Old Mar 27, 2008 | 02:07 PM
Murderface's Avatar
ORIGINAL: Red_sapphire89
no murder face that mod replaces the control unit behind the drivers side wheel
NO RLY?
I'm saying my manual adjustment screws are stripped out, so having that little control unit inside my car to aim my headlights via the adjustment motors instead of using the screws would be very convenient.
And no, that little switch won't fit right in with the TT's panel, you'll have to mod it with a dremel or something. Its only plug+play for MkIV switches which are a bit different.
Old Mar 27, 2008 | 02:32 PM
diehlryan's Avatar
you guys know you can adjust the headlights with vagcom right?
Old Mar 27, 2008 | 06:08 PM
achTTung's Avatar
well, you can go thru the leveling procedure with vagcom, i'm not sure I've ever seen actual adjustment. Normally you'd make the lights go to a start point, then you aim them, and it takes over after that to move them as needed.
