Window problem....Latch sensor?
Ok guys....heres another problem.
Driver's window (coupe) when i lock the car, it goes down half way....pauses, then a little bit more... i unlock the door, get in the car, turn on key try to put window up...nothing, can hear motor ticking take door panel apart remove motor, it turns both ways with switch, move window back up...put motor back on...its fine....UNTILL.....i lock the door, window goes down half way and gets stuck... through searching...ive read that there is some microsensor in the door latch?.....is this what i need to replace?....part number?...pics?.... I have disconnected the window motor clip. ALSO 17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High P1114 - 35-10 - - - Intermittent 17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit P1118 - 35-10 - - - Intermittent Post cat o2.....right?......i get this alot, and want to replace it |
RE: Window problem....Latch sensor?
open circuit means a loose/frayed wire, its grounding out somewhere. the sensor itself might not be bad. might want to check for rubbing wires before you opt to replace.
For teh window, have you done the reset procedure? (window all the way down, then all the way up, release, then hold the 'up' switch again for 2 seconds). |
