WOT box
Just ordered one of these
http://forums.vwvortex.com/zerothread?id=3979857
now to get my car back so I can install/play with it has anyone else here ordered one I would like to see some install pics if you have
so, you keep your foot on the gas... therefore when you press on the clutch thats when the device initiates the "ignition kill" or whatever... so thats what prevents the rpms from spiking? then you get your foot off the clutch and it immediately goes back to gas right?
Basically. It shuts down the coils long enough for you to switch gears so you dont lose psi and have a faster shift. This part alone should allow you to drop 1/4mi times by .3-.5sec. Add in the lauch control and you should also have consistant 1.5-1.8 (awd vs fwd) 60' times. The launch control will keep the TB open so you will also make boost from a stand still. how much depends on turbo size and rpm. Pete of IE only got like 5psi on his 3076r at like 5k but they have SRT's getting to 20psi when they launch. All i can say is 1/4 times will be dropping fast here soon with these little boxes.
