01 A4 center display
Old May 31, 2015 | 03:08 PM
bettysdad's Avatar
Default 01 A4 center display
I have a problem no one's ever heard of much less diagnose.
The center display works perfectly in P or N. When I put it in any gear it goes out EXCEPT for the gear indicator at the bottom.
If I haven't moved and put it back in P or N the display comes back.
If I have moved, the display does NOT come back. Sometimes the OK symbol comes on after moving.
Any ideas?
Old Jun 1, 2015 | 10:53 AM
MetalMan's Avatar
This may sound too simple/silly, but did you try pressing the reset button on the wiper stalk? Pressing that will turn the display on/off, and the display may turn itself on for things like changing gears.
Old Jun 3, 2015 | 03:10 AM
bettysdad's Avatar
MetalMan -
You sir, are a genius. IT WORKED!
Started the car, stepped on the brake, put it in gear, then started playing with the function and zeroing switches.
When the display came on I was so shocked I couldn't remember if everything was actually there, which, of course it was.
This is the first time I've ever fixed a car without tools or money.
Thanks so much.
blackt1ger
Nov 20, 2013 08:33 AM
01A4QUAT
Jan 27, 2013 12:38 AM
Smooth A6
Feb 18, 2012 10:07 PM
cacumm02
Aug 25, 2009 12:31 PM
