01 a4 not starting regularly
i just rebuilt the motor in my 2001 A4 Quattro 1.8T. Once it is starting it runs and idles perfectly. However, it will not always start right away. Often i have to turn the key, let it turn over several times, remove the key, then insert it again and usually it will start on the second or third time of this procedure.
Also, the check engine light is on. I am getting a code saying bad cam position sensor, however i just purchased and installed a new cam pos sensor after the rebuild.
any ideas as to what is going wrong?
im not sure of the code just because i dont have my own computer and am not located near an audi dealer. local shop just told me cam position sensor is bad. because i just replaced it, and it doesnt just not start ever, he thought it could be a short in the wire
What was the reason for the rebuild?
