1.8T AEB - misfires
Any suggestions how to tackle these codes?
Saturday,19,January,2013,14:00:00:36008 VCDS Version: Release 11.11.5 (x64) Address 01: Engine Labels: 058-907-55x-AEBN.lbl Control Module Part Number: 8D0 907 557 P Component and/or Version: 1.8L R4/5VT MOTR HS D02 Software Coding: 06201 Work Shop Code: WSC 00001 VCID: 3D71816537FD06F00AA 7 Faults Found: 17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1 P1196 - 35-10 - Electrical Malfunction - Intermittent 17968 - Maximum Engine Speed Exceeded: Engine Warranty VOID! P1560 - 35-10 - -) - Intermittent 16716 - Knock Sensor 2 (G66) P0332 - 35-10 - Signal too Low - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - Intermittent 16686 - Cylinder 2 P0302 - 35-10 - Misfire Detected - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-10 - - Intermittent 16686 - Cylinder 2 P0302 - 35-10 - Misfire Detected - Intermittent Readiness: 0000 0000 |
Does this one have the ICM delete? If not, just try moving the coil packs around, and if the misfire stays at cylinder 2 it's probably the ICM.
Originally Posted by MetalMan
(Post 1420935)
Links? In the meantime, i took the spark plugs out yesterday, put new NGK 7 heat gapped to 0.028 in. The old plugs looked ok, but found some oil on the boot on 3 of the 4. Will run a scan again after some driving. |
The benefits are great! Smoother idle, smoother powerband, in some cases better MPG and more power (due to larger plug gap), less wiring, fewer components to fail, and these coil packs are only about $20 each.
Do a Google search for "ICM delete" and everything that comes up will pertain to the AEB engine. I'm running a 0.040" gap on my BKR7E plugs, using 06H905115A coil packs. Bought them from http://genuineaudiparts.com/parts/in...&siteid=214407 Usually you'll need to use something like 034 Motorsports adapters to run 2.0T coil packs on AEB or 2.7T engines. These run about $20 each (four for AEB, 6 for 2.7T). |
