1.8T Drinking oil
Old Jan 5, 2011 | 08:58 AM
single speed's Avatar
Default 1.8T Drinking oil
Hi. this is my first post on this site!
just been offered (free!) a 2001 A4 1.8T Estate, which the guy claims has blown its turbo. Aparantly its oil light came on, and he topped it up and it runs ok,, but blows smoke and does about 20 miles to the sump?
there is no mayo in the rocker box sumo or water tank. Is this a common problem? what kind of a job is it to fix? The cars done about 100k miles.
Any help greatfully received!!!!!
Old Jan 5, 2011 | 11:21 AM
Msnickbroderick's Avatar
Actual WIZARD
Get it, and ill buy it! Haha
Welcome to the forums!
It somewhat sounds like a blown turbo, but the key thing to listen for is a dentist drill sound that changes frequencies when you rev it. If he will let you, get to the turbo inlet (15 minutes, a few screwdrivers and wire cutters) and check the shaft for play
Old Jan 5, 2011 | 03:23 PM
Thanks for your message! You are welcome to buy it, but the shipping from Suffolk England to you wouldn't come cheap!!!
Old Jan 5, 2011 | 03:55 PM
turbo kraut's Avatar
Tech Guru
^this... with how you were talking i knew you had to be from across the pond or at least canada
Old Jan 7, 2011 | 08:58 AM
is a repair kit available?
Old Jan 7, 2011 | 09:30 AM
BaconBait's Avatar
You'll have to replace the turbo. Keep in mind that the turbo didn't just decide to quit. Something else is probably wrong in the oil system.
Old Jan 7, 2011 | 09:41 AM
dragonrage's Avatar
There are rebuild kits but if the turbo is that far gone, you need a new one.
Old Jan 8, 2011 | 12:21 PM
Talking Happy Days!!!
Turns out that the only problem was the oil ffed pipe banjo had come loose and was letting the oil out! The Rubber pipe to the turbo was also split. So it looks like new pipe, and a good service should see it up and running ok! Overall, hopefully not a bad swap for a bottle of whiskey!
Old Jan 8, 2011 | 12:25 PM
twoeightquattro's Avatar
^ i like this guy! haha
well good luck with the car! hopefully it turns out!
Old Jan 8, 2011 | 01:09 PM
FASTER's Avatar
Tech Slut
Wow, sounds like you found yourself a deal. Depending on the bottle of whiskey
Where can I find people like this.
