1.8t power steering leaking
so i have a leak with my power steering and it's getting bad. whenever i turn my wheel to the left or right all the way, it leaks pretty bad beneath the car near the intercooler area. i was wondering if this is a hose/line issue or the whole rack setup?
thanks |
The rack is way back under the firewall. Have you looked under there? Up by the intercoolers it about has to be the pump or a hose. Check the hose out of the resevoir..that gets loose sometimes. But since it happens under pump pressure, it's more likely a pressure hose or the pump.
