AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   1997 audi a4 1.8tq PO302 misfire and it's not the coilpack???? HELP!!!!! (https://www.audiforums.com/forum/b5-models-69/1997-audi-a4-1-8tq-po302-misfire-its-not-coilpack-help-187555/)
green2man0 Sep 21, 2012 10:02 PM
So like the titles says its a 97 a4 1.8tq with 180k. Today randomly it started running like a flat 4 (sound). I was guessing misfiring, coil pack, or the plug. I replaced the coil packs around 10,000 miles ago, I also saved the original coil packs numbered by cylinder. The code came up PO302 so cylinder misfire on #2. So I pulled the coil off and switched it out with all the old coil packs (tried them 1 at a time to see if it was the coil pack) no improvement. I started the engine again and pulled out #2 pack and it ran exactly the same...so not getting spark to #2. Pulled the plug and checked gap...within the norm..it did have some heat stress (rainbow swirl on the metal) and there was a bit of black carbon and the spark tip was brown. I cleaned it up and reinstalled. Pulled the battery and checked the voltage...it was good 12.6v, cleaned all the terminals, reinstalled.
The only odd thing was when i took it to the auto parts store to get it scanned he could not reset the codes...he said the obd2 scanner could not reset it????
Also there was a PH76 code I could not find info on the description was: manufacturer specific power train.
Any Ideas....I'm probably gonna have to take it to the shop on Monday.
Thanks,
Aaron S
redline380 Sep 22, 2012 12:57 AM
bad icm, or wire to #2 coil pack.
BaseDrifter Sep 22, 2012 02:52 AM
Yeah, most likely a bad ICM.
green2man0 Sep 22, 2012 10:56 AM
Just another quick question. Would the car being chipped prevent the obd2 scanner from resetting the fault codes. I'm gonna look into the icm, i did't see any frayed wires on the coil pack harness.
Thanks for the info, very much appreciated
Aaron S.
