2000 a4 turbo
I have a 2000 a4 turbo with a bad head,i do have another head but it is a vvt head off an 04 ...will this newer head work if I put the non vvt tensioner on it or not...do I have to switch cams or can I run the vvt head the way it is thanks
Originally Posted by robertpedie
(Post 1451406)
The intake cam is a different part number so it would be best if you swapped it in, and like redline said you don't actually have to swap the tensioner so just use whichever one is better/newer.
| All times are GMT -4. The time now is 04:45 AM. |
