65535 - Internal Control Module Memory Error
Old Jun 12, 2012 | 01:12 PM
jj fad's Avatar
Default 65535 - Internal Control Module Memory Error
I can't get my new A4 1.8T inspected and registered because of the Airbag Light on. Someone offered to help me clear the code but his (full version) Vag-Com couldn't erase the code.
00-10 - - - Intermittent
Previous owner mentioned it's the harness under the passenger seat that triggered the light. I dunno!!!
Is replacing the airbag module the only way to get this fixed?
Let me know
Old Jun 12, 2012 | 02:11 PM
CCA4's Avatar
The loose connector under the seat wouldn't cause this. Do you still want me to take a look at it today or would you rather wait until it stops raining?
Old Jun 12, 2012 | 02:16 PM
jj fad's Avatar
Chris, PM me your number...
Are you available after work? I can stop by to your place.
Old Jun 12, 2012 | 02:21 PM
CCA4's Avatar
Inboxed you on Facebook. Hope it stops raining! lol
Old Jun 12, 2012 | 04:37 PM
trev123's Avatar
i had same problem and bought a secondhand airbag module with same part number . the airbag module brakes down, audi waned 800 pounds fitted took me 40 minutes and 45 pounds , i then had to clear airbag light with my faultcode reader.65535 you need new or secondhand module
Old Jun 12, 2012 | 08:54 PM
CCA4's Avatar
Jun just left. I can communicate with the module with my ECS scanner but it fails all of the output tests. I told him to pick up a new module or rebuild his. Nice guy! (rare in these parts )
Old Jun 21, 2012 | 10:43 PM
jj fad's Avatar
UPDATE:
I replaced the airbag module and got it soft coded using ross-tech vagcom but the light is still on. What else could it be???
HELP!!!
Old Jun 21, 2012 | 10:44 PM
CCA4's Avatar
Ahhhhh fack. Did you try the zip tie fix under the seat?
Old Jun 21, 2012 | 11:02 PM
jj fad's Avatar
Not yet Chris. I checked the connections and it looks good.
I'm gonna try to zip tie it this weekend.
Old Jun 27, 2012 | 08:26 AM
jj fad's Avatar
UPDATE:
I did the tie wrap trick and everything but the light is still on.
