98a4 door panel removal
Old May 19, 2014 | 10:21 AM
1998a4's Avatar
Default 98a4 door panel removal
Good morning everyone. We just purchased a 98 a4 and I need to get the door panels off. I found 3 screws only. Do they just pop off after I pull those? I dont want to break anything. Thanks
Old May 19, 2014 | 11:05 AM
MetalMan's Avatar
Hi, and welcome. I moved this thread to the correct section so you'll get the best responses.
To answer your question: there is one short screws on each edge of the door (2 total), towards the top of the door panel. Then there is a screw under the grab handle (not the handle that opens the door). Once that grab handle screw is out, then you can remove the plastic trim on the underside of the grab handle, and you will expose one or two more screws that hold the door panel to the door. Once this(these) screw(s) is(are) out then you can lift up on the door panel, and unclip anything on the backside.
Old May 20, 2014 | 08:49 AM
1998a4's Avatar
Thanks for the reply. Sorry about posting in the wrong area. There is a few other things such as burning oil smell, oil filler cap leak, loud power steering pump and little markers on the fenders dont work. Just yo name a few......
tuned2.7A6
Aug 25, 2011 06:56 AM
stenicilyg
Jan 6, 2010 08:04 PM
auS4di
Jun 25, 2006 01:51 PM
auS4di
Jun 22, 2006 09:16 PM
sharkbait
Sep 7, 2004 12:17 PM
