99 A4 2,4 Tiptronic problem
Old Nov 21, 2011 | 04:24 AM
kuven0107's Avatar
Default 99 A4 2,4 Tiptronic problem
Hi all.
I am new to this forum and require some assistance and/or advice.
I have a 99 A4 2,4 Tiptronic, and I seems to have a problem with the transmission/gearbox. It can select all the gears but only moved in Reverse. When you put it into Drive, or 2,3 or 4 and you press the accelerator it does not move.
What is the cause of this? or is the whole transmission/gearbox damaged?
Old Dec 4, 2011 | 11:41 PM
kuven0107's Avatar
I picked up these faults with VAGCOM cable..
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 R
Component: AG5 01V 2.4l5V RdW 8518
Coding: 00000
Shop #: WSC 00000
VCID: 3C7330C304AB
5 Faults Found:
00300 - Transmission Fluid Temp. Sensor (G93)
30-00 - Open or Short to Plus
00268 - Solenoid Valve 6 (N93)
31-00 - Open or Short to Ground
00266 - Solenoid Valve 5 (N92)
00270 - Solenoid Valve 7 (N94)
00264 - Solenoid Valve 4 (N91)
Old Dec 5, 2011 | 07:34 AM
jonbonesjones's Avatar
Moderator
00300 - Ross-Tech Wiki
a sympton is tranny not shifting properly. Thats just for the fluid temp code. Idk about the other ones but I'm gonna guess they have something to do with the tranny control module?
Old Dec 9, 2011 | 05:40 AM
kuven0107's Avatar
Hey dude.. Thanx for the repsonce.. Was doing a bit of searching on google and seem that people have issues where the TCM gets water damaged... Need to check that also..
abiv95
May 20, 2013 05:27 PM
Dadan
B7 Models
Dec 6, 2011 04:30 PM
ramses
Jan 26, 2009 11:31 AM
QuickQuattro
Jun 26, 2007 07:56 PM
bAyArEaTQ
Jan 24, 2007 09:25 PM
