A4 B5 Electrical Mirrors not working
Old Sep 11, 2009 | 07:19 PM
marlboro's Avatar
Default A4 B5 Electrical Mirrors not working
Hi,
The electical mirrors on my A4 1.8 B5 model stopped working. I checked the fuse and it was blown. Replaced it but both mirrors are still not working. Any ideas what might be the problem and where should I start looking first?
Old Sep 11, 2009 | 07:26 PM
Andrew149's Avatar
check that fuse again prob a bad ground try a bigger fuse...
Old Sep 11, 2009 | 07:43 PM
Mr. Phil's Avatar
idk if u know how or want to, but try popping the door panel off and looking at the connection... when i first got my car the power mirrors didnt work either, i replaced the fuse just like u but still nothing... i think checked the connector and the clip was broken and i had to put it back in and zip tie them together and i havent had a problem since
hope this helps...
and see i dont always thread jack and give worthless info andrew lol
Old Sep 11, 2009 | 08:07 PM
marlboro's Avatar
Done that. Tried 20A instead of the original 10A but still no luck.
Old Sep 11, 2009 | 08:10 PM
marlboro's Avatar
hope this helps...
Is that a complicated job? I think, I've seen a guide on the net of how to take door panel off but are there any specific things to watch out for while doing it?
Old Sep 11, 2009 | 08:55 PM
Andrew149's Avatar
wow umm i hav 205k on my car and no promblems with the mirrors have you tested the switch? maby for power?
Old Sep 11, 2009 | 09:12 PM
marlboro's Avatar
Is there a way to test that without removing the door panels?
Old Sep 11, 2009 | 09:15 PM
Mr. Phil's Avatar
No not complicated, there are 2 screws at the top of the panel, one on the outside and one on the inside (edge of door and next to door hinge), there is also 2 screws behind the lil piece in your handle by your window control, pop that lil black piece out by removing the screw and there are the 2 screws underneath that area, once u do that go to top of door panel with window down pull up the panel over the door but be careful of your door lock, then lift straight up and pull the sides out lil by lil as the hooks are pointing down, I'm sure there is a vid online but incase u can't find one that's the best description I can give
And when u do remove the door be careful of you windows anf your door speaker wires so u don't rip them out... Hope that helps and u get your problem fixed
diarmuid
Jun 3, 2015 08:59 AM
aburrows88
Dec 12, 2013 06:10 PM
dean.beagan
B7 Models
Aug 18, 2013 04:16 PM
b5turbony
Jun 18, 2007 10:58 AM
cary12
Oct 21, 2005 10:59 AM
