a4 running hot
Old Jun 21, 2008 | 11:35 PM
tln708726's Avatar
Default a4 running hot
Today I just bought an 1997 A4 2.8 non turbo. It only has 75k miles om it and thought I got a great deal. When driving it home I thought it was running hot because the water temp guage was at 3/4. I pulled over and the electric fan was working, water pump was not leaking and seemed fine.Even though it was 114 out in the AZ heat it just seemed hot.When I got home I turned on he heater and it cooled down to middle of guage at an idle. So I'm thinking I got taken and the water pump is going out. Anyone have any ideas of what else it could be and where can I find step by step of replacing water pump. Anyone try it before?
Old Jun 22, 2008 | 01:06 AM
david9999's Avatar
Default RE: a4 running hot
Water pump or thermostat is stuck.
Old Jun 22, 2008 | 05:03 PM
tln708726's Avatar
Where is the thermostat located on the A4 2.8. I order a new one today but might just take it out for now and see it it fix it.
Old Jun 22, 2008 | 05:37 PM
tln708726's Avatar
As is it normal on the audi for the cooling fan to turn off when you turn oof the car and it's hot? On my acura it runs till the car is cool enought.
Old Jun 22, 2008 | 05:52 PM
hiwords's Avatar
yes because if you can't tell, the coolant still flows. the thermostat should be on the passengerside right next to the water pump
Old Jun 24, 2008 | 10:19 PM
andreigbs's Avatar
Member
If you can see coolant flowing into the expansion tank, your water pump is good. Odds are you need a new T-stat. I'd go with a lower-than-stock temp rating if I lived in AZ
Old Jun 24, 2008 | 10:46 PM
ImTheDevil's Avatar
Agreed on all counts. What sucks about the 2.8 in this case is that it's an assload of work to change a cheap part. Prepare to remove the front of your car to get to it. It's not difficult at all - just takes time. Plan a full day of work and get ahold of a shop manual to help you along the way.
inflictor
Jan 19, 2017 01:48 PM
So-Cal
Apr 7, 2013 01:47 PM
susyhun
Sep 30, 2011 05:31 AM
EnviedA6
Nov 16, 2007 05:38 PM
A4 Effort
Jun 15, 2007 07:29 PM
