ABS light, no code?
I have a solid abs light on. I scanned the comp with my scangauge, but no codes came up. On the scangauge site, its says its compatible. Do I need a different reader? Or dont abs codes come up? Also have an airbag light from the blown airbag, is there any tool besides the pricey vag-com?
This is all I found on ebay
http://cgi.ebay.com/VW-AUDI-SEAT-SKO...sid=p1638.m122
I do plan on doing most of my own work, and I do plan on owning audis for a while. But sheesh 250 bucks. And its only good for audis?
Yeah hiwords is right, if you get the ebay version you can save a lot of money and keep like 80% more of the usefull functionality. Here's the break down of the differences. http://www.ross-tech.com/vag-com/vag-functions.html
Will I be able to get rid of my airbag light and check brake codes? Theres really nothing else that I want to do besides read and clear codes. Its just a 12v 2.8. Not much to care about. If I pick up an S4 I might opt for the real deal.
Oh and I didnt see the cable on ebay that was mentioned. Is there anything I should look out for or stay away from? They are all roughly the same price.
Thanks for the help!
ORIGINAL: TheBat
Also 250.00 still isn't bad for what you can do....I kick myself for they used to be 150 for a full version.
