Abs light staying on need help
Wheel Sensors...
The wheel sensors are pressed into the hub pointing towards the driveaxles. You will see a black wire running from under the car in the rear, or through the inner fender in the front. Some people have had luck using some brake cleaner to flush out around the cv joint, cleaning debris from the hole on the business side of the sensor but more than likely the sensor will need to be replaced.
When I got my 96 a few months back, both the ABS light and BRAKE light were on all the time due to bad wheel speed sensors.
I would first start with looking into VAG-COM to retrieve codes, so you are not chasing your tail..
Hope this helps
Hope this helps
